Publisher: Activision
Built on an updated version of id Software's
Doom 3 engine,
Enemy Territory: Quake Wars is a team-based first person shooter that recently obtained the title of being the first game to use John Carmack's megatexture technology: a single texture that spans the entire map.
ET:QW also makes use of many vehicles and large open areas which means the action in view can get really intensive in this team based shooter. It's also the only game in this suite that utilises OpenGL instead of the pretty much industry-standard DirectX API. We used the full retail version of the game patched to version 1.4.
We recorded a timenetdemo on the Valley level which lasts for several minutes during an online game - this used lots of the different graphical effects to create what we've deemed to be a fairly typical slice of action to stress the system. We also created a custom autoexec file that enabled ultra high video settings, over and above that of the standard in game "high", including soft particles, as ATI has now remedied the display corruption present with that option enabled.
        Nvidia GeForce 8800 GT 512MB
        Zotac GeForce 9600 GT 512MB AMP! Edition
        Nvidia GeForce 9600 GT 512MB
        Nvidia GeForce 8800 GS 384MB
        ATI Radeon HD 3870 512MB
        PowerColor Radeon HD 3850 Xtreme PCS 512MB
        ATI Radeon HD 3850 256MB
        Nvidia GeForce 8600 GTS 256MB
        ATI Radeon X1950 Pro 256MB
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
    Frames Per Second
    Frames Per Second
    Frames Per Second
Nvidia has a strong showing in our final test,
Enemy Territory: Quake Wars, where it manages to outperform the Radeons pretty convincingly at both 1280x1024 and 1680x1050 with 0xAA applied.  Like
Oblivion though, the Radeon HD 3870 doesn't disappoint when anti-aliasing is enabled and it manages to edge a lead over the stock GeForce 9600 GT at 1280x1024 while the lead is a bit more convincing at 1680x1050 4xAA.
That isn't enough to beat off the Zotac GeForce 9600 GT AMP! Edition though and again, the card manages to perform at the very least in line with where we would expect it to, if not exceeding our expectations.  It's right on the heels of the standard GeForce 8800 GT, which suggests that the game isn't as shader limited as some of the other games tested.
